This command clears the accumulated PTP packet counters. The clear can be performed on the following groups:
Per unicast-master or unicast-slave peer on a clock port.
Peers on a clock port.
Peers on all clock ports.
This command is available only for Boundary and Ordinary clocks.
| network-clock | External Clock for Ethernet synchronization. |
| ptp | Precise Time Protoco.l |
| boundary | Boundary clock. |
| ordinary | Ordinary clock. |
| vlan | VLAN. |
| ipv4_address | Peer IP address. |
| unicast-master | IP addresses that are masters to the local clock. |
| unicast-slave | IP addresses that are slaves to the local clock. |
| all | All VLAN. |
| counters | PTP message counts. |
N/A.
Use this command to clear the accumulated PTP packet counters.
N/A.
This command was first available in ExtremeXOS 15.2.
This command is available on 7520-48Y and 7720 platforms.
PTP commands can be used only with the Premier license pack.
